application of decals on new paint
jubilee johnny
01-09-2007 11:29:48
How soon can vinyl decals be placed on catalyzed new paint? I don't want to get in a hurry.
Rod (NH)
01-09-2007 15:10:31
 Re: application of decals on new paint in reply to jubilee johnny, 01-09-2007 11:29:48
Johnny,
Here's some general guidelines on vinyl decal installation. I believe the 60 days mentioned is probably for uncatalyzed enamels. In any event, when I did mine, I wanted to clear over them and had no intention of removing them later. The paint was acrylic urethane (necessarily catalyzed). I wanted to maintain a chemical bond with the clear (to be applied after the decals). To stay within the clearing window (1 week for the particular paint I used), I applied the decals two days after the color and cleared that same day. That was several years ago and absolutely no problems have shown up. The tractor is outside 24/7/365. I personally think the vinyl decals have a better appearance with a clear over them. The edges of the thicker vinyl decals are smoothed and "blended" into the surrounding paint that way. It gives the decal more of a painted-on appearance as well as providing a measure of physical protection. At least I think so.
Rod
jubilee johnny
01-09-2007 17:20:01
 Re: application of decals on new paint in reply to Rod (NH), 01-09-2007 15:10:31
Thanks. I am doing a 41 jd "h" so the hood is the main area where your idea of clear would be. But, the grills amd medallion would need to be done, too. Would there be a noticable difference if the frame was not done with clear? Thanks.
Rod (NH)
01-10-2007 06:35:42
 Re: application of decals on new paint in reply to jubilee johnny, 01-09-2007 17:20:01
If it were mine, I'd plan on clearing all the smooth sheetmetal, even where there are no decals, just to assure there would be no difference in appearance. That's what I did.
Rod
B-maniac
01-09-2007 19:18:32
All paints , catylized or not , cure at different rates. A good rule of thumb (no pun intended) in to use the ole thumb print method. (in an inconspicious area) If you can print it , don't decal it yet. Clear/no clear areas shouldn't look any different if sprayed the same. As far as clearing over decals , Rod has had good luck , I myself wouldn't do it. I don't believe paint is designed to adhere to a glossy vinyl finish and I also believe that a vinyl decal will shrink and expand in the sun/shade at a greater rate than clear coat does and therefore will eventually delaminate. Besides , it sounds like you have already painted it and are waiting to put on the decals. If you are going to clear coat , it has to be soon after you paint (window) (wet on wet) to chemically adhere. Also depending on your clearing experiences , those decal edges can very easily cause a perfect place for a run to start. That clear will react (flow) differently on that slick decal than on the other paint. Just a few things to think about before you decide which way to go. Personally , I think it's a lot to worry about for the minimal gains you may get.JMHO.
