when clear coat ??
Dutchman
01-14-2007 15:09:27
Hi, I'm no painer by any means,..the last time I painted something was years ago...now I'm getting into restoring older tractors and plows I'm painting again... I bought a HVLP paint gun [ not a expensive one ] I use it Sat to prime a plow...WOW...I could SEE ...not a cloud... STUPID Question...when do you CEAR COAT ?? [ No I'm not going to clear coat my plow ] was wondering... When I paint my plow w/hardener.... I paint the 2 coat while it's still WET ?? IS THAT RIGHT ??
THANKS for ANY and ALL ADVICE I get...I do APPRECIATED it.....Mark
Rod (NH)
01-14-2007 16:20:40
 Re: when clear coat ?? in reply to Dutchman, 01-14-2007 15:09:27
Hello Mark,
You only have to use a clear coat if you use a two stage basecoat/clearcoat system as currently used on most automobiles. Clearcoating a single stage paint is optional. Most will argue it's unnecessary and it would be in most cases. Any type of automotive paint you use should be applied in successive coats with only a short dwell time in between unless you want to sand between coats. That dwell time is typically 15 minutes or so. Adding more coats at a later time, say days later, w/o sanding will not provide good adhesion between the coats. That's true whether or not a hardener is used.
third party image Rod
B-maniac
01-14-2007 16:53:50
 Re: when clear coat ?? in reply to Rod (NH), 01-14-2007 16:20:40
Rod is correct about the clear coating. As long as you aren't painting any metallics etc , you won't need it. The first time you find yourself painting silver met. single stage on anything will probably be your last. Then you will go BC/CC. I use it on virtually everything but that's just what I do.Glad to see another farm equip. painter on board.Best of luck.
Dutchman
01-14-2007 18:15:11
 Re: when clear coat ?? in reply to B-maniac, 01-14-2007 16:53:50
THANK YOU...THANK YOU...now if it warms up some so my shop furance doesn't have to run so hard...I will try painting again.... Again many THANKS....Mark
