Homemade Paint booth
GlenIdaho
01-23-2007 17:26:25
I'm working on an old Ford tractor and have prepped the sheetmetal for painting. Unfortunately the weather here is in the 30's and 40's duirng the day, below freezing at night. I have a shop that is heated with a direct vent heater so the pilot and burner are not exposed to any indoor fumes. I have created a booth inside the shop by hanging 6ml plastic from the ceiling. I have a fan that exhausts through a window. I want to use Omni epoxy primer and acrylic urethane on the sheetmetal as that is what was used on the rest of the tractor last summer when I painted it outdoors. I use a HVLP gun. Now to the questions;
Should I have any concerns about spraying in the homemade booth? i.e. static electricity in the plastic sheeting, do I need to keep the shop heated after painting until the paint cures or can I turn the heat down a bit? Anything you folks can think of. Thanks for the help.
CNKS
01-24-2007 12:57:01
 Re: Homemade Paint booth in reply to GlenIdaho, 01-23-2007 17:26:25
I am in a situation similar to yours except that the outside temp "usually" isn't below 40 or so. I have fans designed for paint booths that move a lot of air. I try not to paint for more than 5 minutes or so, often less so that the temperature does not drop too much due to the cold air in, warm air out thing. I start at 70 degrees, and as yet have not seen it drop below 65. Afterward I either run my natural gas furnace at 65 or so all night, or I sometimes put an electric space heater in the door of my 8 x 10 wood/metal booth, with the furnace off, not sure which is cheaper. I have not had any problems with that. As to static electricity, it isn't a problem for me because the fumes are not accumulating, if you are using only an ordinary fan, you will probably have some fume buildup, increasing the chance of a spark of any kind causing problems. I have sealed explosion proof fans. NO fumes get into the wiring of those fans. If you are using an ordinary exhaust fan you are probably INCREASING the danger of an explosion/fire because you are pulling all the fumes through that fan. In my opinion, if that is the case, you are better off with no fan at all. If you must use the plastic sheeting, push the air in and out with a fan out of the stream of air flow/fumes. You are using hardener -- a supplied air system is required, particularly if you are going to keep doing this. The effects of iso's are cumulative. Could be days, weeks, months, or years before you feel the effects. For me the extra $500 or so for fresh air for my lungs is well worth the money. I do not mean to sound harsh, but I thought all this through before I built my shop and booth and read everything I could get my hands or computer on. I do not regret doing that.
glennster
01-24-2007 11:06:15
it sounds like you're doing good planning for your spray area. the homemade booth will probably suit your needs. yuo may need to get a fresh air supply coming in to the shop, you could open a window, and place a furnace filter in it to try and cut down the dust, close the window after the spray fumes clear wet the shop floor down just before you paint, that will also help keep the dust down. also at least, get a charcoal respirator, they made disposable models for 30 dollars or so. use a cold temperature reducer, it will speed your flash off between coats, and get it dryer a little quicker, definately like b maniac says, keep it warm for 24 hours.
B-maniac
01-23-2007 18:50:34
Yes , you need to keep heat in there for at least 24 hrs , preferably longer.
GlenIdaho
01-24-2007 08:00:27
 Re: Homemade Paint booth in reply to B-maniac, 01-23-2007 18:50:34
B; Thanks for the reply. Been doing some reading of previous threads on this subject. I'm not so sure my homemade booth would be the safest way to go. I may have to wait until spring. I was hoping to have it done by then. Thanks again for the help.
