Sandblasting A Tractor
Greg77
01-24-2007 11:01:51
I've got a 1086 I just got. Have to reset the wheels anyway so I think if I can get some time I'm going to repaint the tractor. I have a couple of sandblasters and sandblast a lot of things some times things I shouldn't. Sandblasting at least some of the tractor would really speed things up. For you guys that have sandblasted a tractor how much can you sandblast and where do you get into trouble.
Thanks, greg
GlenIdaho
01-26-2007 14:34:49
 Re: Sandblasting A Tractor in reply to Greg77, 01-24-2007 11:01:51
Greg; Some food for thought. I have a Ford 850. I used a wire wheel on the transmission, differential and some small parts I didn't want to sandblast. The wire wheel did a great job of removing old paint, about four layers. As was stated in the other posts, the parts I could remove I sandblasted outside and away from the tractor. Some of the sheetmetal I had done by a professional and was relatively inexpensive. If you do the whole tractor expect to spend some time cleaning the sand out.
Here's something I learned today. The finer quality sand does a better job and I was able to have more control with air pressure and delivery rate. Hope this helps.
CNKS
01-24-2007 13:28:55
Greg, I read your post above before this one. Forget what I said. The 1066 was IH 2150/PPG 71310/DuPont 96766. But, the current 2150 is NOT the same color that came on your tractor, as somewhere along the line it picked up an orange tint -- I have used 71310 and it has some orange in it -- I had my dealer change the formulation slightly to get rid of some of the orange, don't think I quite went far enough on my 460. I have heard, but not seen, that 96766 does not have orange in it -- paint colors are a crap shoot.
CNKS
01-24-2007 13:34:11
 Re: Sandblasting A Tractor in reply to CNKS, 01-24-2007 13:28:55
As to sandblasting, I don't sandblast anything that I can't remove. You can tape over bearings, etc, but sand has a habit of getting into every place it it shouldn't. Others claim to have had no problems, not worth the risk to me.
BillD1
01-24-2007 13:53:40
 Re: Sandblasting A Tractor in reply to CNKS, 01-24-2007 13:34:11
In my opinion that is the quickest way to ruin a tractor. Never sand blast any part that you can`t get at least 25 foot away from the tractor
