what kind of sandblaster to buy
tractor Hank
01-30-2007 19:51:18
I am completely restoring my first tractor and need to know what kind of sandblaster is the best to buy. I have a 60 gallon air compressor up to 135 psi. Will a siphon type work with my air compressor and what should I look for, or will a pressurized 10 or 20 gallon tank type work better. Also what is the best media for sandblasting the frame and big cast iron pieces. I understand it is not a good idea to sandblast body panels like the hood. Thanks, Hank
beperson83
02-15-2007 10:04:58
 Re: what kind of sandblaster to buy in reply to tractor Hank , 01-30-2007 19:51:18
I have a Gravity Feed sandblaster. It was only like $45. It works perfect for little areas. Ive used a big expensive one before and I dont really notice the difference between the 2. I bought mine from my local Snap-On dealer. You can pick them up from a lot of places.
Brad_bb
02-05-2007 14:14:05
Unless you are going to be doing a lot of sandblasting(1 tractor isn"t a lot), then I would recommend to have it professionally sandblasted. Still you must properly prepare the tractor - remove the engine, seal up the bell housing, duct tape the PTO Opening, Wrap the steering wheel so the plastic doesn"t get blasted, remove everything you can, duct tape and protect any critical areas and anyplace sand could possibly get in. See my picture sight and how I prepped my tractor for the blaster. I also left my wheels on so it could roll, and then after it was blasted and back at my shop, removed the wheels and removed the tires from the rims and had the rims blasted/stripped separately. Have the engine builder do the engine stuff, not the blaster.
GlenIdaho
02-02-2007 15:53:14
Hank;
I wore out one compressor sandblasting my tractor parts because it was too small. I upgraded to a 60 gal tank and just did some parts the other day. I picked up some 70 grit sand(very fine) and found that it enabled me to adjust my pressure blaster and did a good job. gave me better control. My compressor had to work to keep up. The bigger the better. As was stated be sure to wear a good respirator.
I also had some sheet metal done by a local sandblaster who knows his business and had no problem with metal warping. If you have someone local, stop by and talk to him about his experience and warping issues. If he's good he'll know how to do sheetmetal. The cost is relatively inexpensive and to me is worth the cost. If your concerned about sand getting in your tractor, do the masking before you take it to him.
There is also soda blasting which eliminates the warping issues, does no harm to the metal, but is more expensive.
I have an 850 and cleaned the trans, hydraulic housing, differential and some small parts using a wire wheel. It took all the paint off and didn't hurt the metal. Home this helps you!
SuperA-Tx
01-31-2007 07:52:21
I did my first tractor this past summer and would do things differant if I had to do it again. I used a siphon sand blasting gun from Tractor Supply and it worked OK after I got a big enough compressor to do the job. A few things I found out tho, you dont get enough volume and it takes FOREVER to get anything done especialy if your doing cast metal and blasting thru six coats of paint. Sand dust gets everywhere. Tips wear out pretty fast too.
Now if I had it to do again I would take everything I could to a regular sand blasting guy and let him do it for me. They can do in an hour what it will take you a month to do with a small sand blasting gun. You might even get them to come to your place and blast it and that way you could keep things straight.
If you do decide to do it yourself wash the tractor down first and try to get all the dirt and greese off cause sand blasting wont cut that. Get lots of oven cleaner to take the paint off, it works good and will save lots of time.
gonzo in michigan
01-31-2007 05:22:09
Do not waste your time with a siphone type blaster. they are slow and waste sand. The preasure types are much better. I have 10 gallon one from TSC i bought a few years ago and has given me good service. Its good enought for the hobby user. Sometimes i think a larger sand tank would be nice but usually when its time to refill i am ready for a break anyways. I have had to replace the wear parts like tips and nozzle parts but this is normal for any sandblaster. Your compressor is big enough. Thats all i use with good results. As far as sheet metal damage that only applies to the really big high power commercial rigs used for really big things. I just use white silica medium grit that can be purchased at pool supply and builders supply places. Its cheap does a good job and can be reused once or twice if kept dry and clean of stuff that will plug your nozzels. The most fustrating thing about sand blasting is keep your hood lens fog free and clear. I buy plastic lens from a welding supply and replace them as they become badly pited. I assume you are hobby restorer like me and that you do not have ton of money to spend.
B-maniac
01-31-2007 18:26:13
 Re: what kind of sandblaster to buy in reply to gonzo in michigan, 01-31-2007 05:22:09
Use pressure type blaster. Do not take it to commercial blaster , they WILL get sand INSIDE your tractor and they WILL warp your sheet metal... If you blast it , mask,mask and more masking , seal EVERY place that a grain of sand could get in. Whatever you blast with , use a respirator or supplied air respirator. Free silica, when breathed in, will dammage lung tissue. Did I mention MASKING? Take your time and do it right and when you think you have it , go around it again. You are bound to find a place you missed. Others will tell you not to sand blast. There is no margin for error when masking. Do it right and there is nothing better than blasting. Do it wrong and it will be expensive down the road. Everything in life follows these same rules. If you can't do it right , don't do it. You will pay. Do it right and reap the rewards.
