New Sheet Metal Parts
SamMI
04-29-2002 09:22:44
Got several new OEM parts. They came with a black primer type coating. Should this be removed and then prime parts again prior to painting? What is the black coating? Thanks
Rusty Jones/ The Mower Man
05-03-2002 18:23:10
 Re: New Sheet Metal Parts in reply to SamMI, 04-29-2002 09:22:44
note: The black primer on the new parts should be sanded with some dry sanding paper. Make sure all of it is roughed up. Use 240 or 280 sand paper. Some of it will come off, but just clean it up good after sanding, then spray the primer. (compatible with the finish paint you are going to use.) some of the older primers won't work well with the new paints. Rusty Jones
