What Reducer to Use
Pete
04-29-2002 18:38:45
What kind of reducer should I use for some acrylic enamel paint sold by Case/International. (I can't make out the label on the can anymore...)
Pete in NY
Rod (NH)
04-30-2002 09:36:58
 Re: What Reducer to Use in reply to Pete, 04-29-2002 18:38:45
Hi Pete,
I would recommend you go to wherever Case paint is sold and note the manufacturer's requirements on a clean label of the same paint that you have.
Rod
Jerry B
04-30-2002 08:50:45
If the paint in question truly is acrylic enamel, then any quality Acrylic enamel reducer should work fine. I would mix about 1/2 of a coffee cup of paint, reducer and hardener first and spray it on some old metal just to make sure it doesn't curddle up before commiting to spraying my tractor.
