How to get rid of pit marks
Paddy
04-30-2002 04:33:05
My 1956 FMD Bonnet has been resprayed but is covered in loads of pit marks all over. It looks ok from a distance but when u get near you can see all these little pit marks, obviously caused from previous rusting.
I was wondering how to get rid of these pit marks ready for painting, or do you apply some special stuff that fills them in. I heard of using body filler, but that will crack in the sunlight when it expands.
Any help would be much appreciated
IK
05-07-2002 06:02:56
 Re: How to get rid of pit marks in reply to Paddy, 04-30-2002 04:33:05
I recomend using a metal top coat by Dupont I have used it alot for filling pits in paint. It works just fine if you don't want to remove all the paint on the tractor. Just lightly sand or steel wool the area and apply a thin coat. It won't crack or peal and it will stick to the paint that is already on the tractor.
Paddy
05-09-2002 09:26:13
 Re: Re: How to get rid of pit marks in reply to IK, 05-07-2002 06:02:56
Thanks for all your ideas guys, they have been really helpful, one question though, with the metal topcoat by Dupont, do I apply it with a brush or a spray gun?
Paddy
05-09-2002 09:21:22
IK
05-07-2002 06:02:26
Rod (NH)
04-30-2002 09:44:07
Hi Paddy,
You might want to try some two part finishing putty. I have recently used some for the first time that is made by 3M. It seems to work well in filling in pitted areas. The proper time to use it though, is before topcoating...not after. See link.
Rod
Jerry B
05-01-2002 06:49:39
 Re: Re: How to get rid of pit marks in reply to Rod (NH), 04-30-2002 09:44:07
Rod,
I have used finishing putty like you described. There are several brands, but they all have one thing in common: They are just high grade body filler.
Paddy was worried about bondo cracking from heating and cooling. This would only be of concern on the hood or near the radiator. E-prime is not as affected by the heating and cooling as bondo.
I am thinking that the type of pits Paddy is talking about is rust pits caused by long exposure to the elements. Although it is possible to spot putty them, it would take a lot of putty and time. Primer is the fastest and easiest way of dealing with rust pits, I have found. I used 3M spot putty quite often and it is a very good product.
Jerry B
05-01-2002 06:15:27
Rod,
Jerry B
04-30-2002 08:27:44
I would sand until most of the paint is gone. Prime with epoxy primer, let set about 15 minutes and prime again.
Set the primer gun in the fridge while your e-prime dries. Use 180-150 grit paper and a sanding block (or DA if you have one), and sand the surface until the area between the pits has most of the primer removed with primer still in the pits.
Fetch your primer gun and prime again. Wait a few minutes and shoot another coat.
Return primer gun to fridge.
Let dry and sand again.
Repeat process unitl satisfied.
Like the instructions say : "Lather, rinse. Repeat."
