dupont color
log cabin farms
02-06-2007 16:38:22
what is the name of the red dupont polyurethane paint for a farmall tractor because i found several different reds. about how much does it cost to paint a farmall M tractor. thanks for any help.
CNKS
02-06-2007 18:02:34
 Re: dupont color in reply to log cabin farms, 02-06-2007 16:38:22
Up to mid 1949, 7410 (IH 50), 1961-up 96766 (IH 2150). In between were IH 1102 (1949-1958), and IH 201 (1958-1961). I do not know if there are codes, Dupont or otherwise for 1102 and 201. Most just accept 2150 as the color of post 1949 tractors. As to cost, $175-$200 a gallon for the Nason version, $350+ for Imron. Those numbers are a guess, as I use PPG. You will need a minimum of 5 quarts for an M, more if you paint all parts separately. Ask your dealer for exact prices. The numbers I gave do not include reducers, primers and primer surfacers which will cost almost as much as the topcoat. It will not be cheap.
