rust
1941 farmall a
02-07-2007 20:43:20
Hi ever one i was just wondering what is the best way to sand the rust off my farmall "a". I dont have the money for a sandblaster and i was thinking of 180 grit sand paper but i dont know at all. Thanks all for your help 1941 farmall a boy
CNKS
02-08-2007 08:09:38
 Re: rust in reply to 1941 farmall a boy, 02-07-2007 20:43:20
The electrolysis process is probably ok, I haven't had much of a desire to use it, as I either wire wheel or sandblast the smaller items. On large items such as the gas tank, hood, and grille, I use a fiber wheel on an electric drill (3M corp, etc). It is slow, but it goes to bare, clean, metal, leaving no rust. It will leave rather deep scratches, which I then sand with 150-180, coat with epoxy primer, followed by a sandable surfacer. That takes care of the scratches. If all I have is paint, I strip it with chemical stripper, then sand any underlying rust off with 180. You don't have much choice on the engine and chassis but to use wire wheels on electric drills or angle grinders. Remove the baked on grease and old paint with a combination of oven cleaner and chemical stripper, pressure wash before and after, will probably take 2 or 3 applications. I think F.I.T. has a recipe for "lye gravy", which tends to make the lye (sodium hydroxide) remain on the surface longer without drying out, making the lye react longer. I sometimes use a rust converter such as Picklex 20 on the nooks and crannies that I can't get to.
F-I-T
02-08-2007 10:58:26
 Re: rust in reply to CNKS, 02-08-2007 08:09:38
The nice thing about using electrolysis is that it will lift the paint, or oil, or grease, AND convert the rust to inert black oxide so the surface is ready for primer as soon as it is dry, in one step. And, you don't have to stand there and do anything. I typically load the tank, then go on the road for a week, and unload clean parts later. But generally speaking, it takes overnight, but sometimes I can get good results in a few hours, but that depends on how much rust there is to be converted, and how thick the paint is.
Here's the link to the "Lye Gravy".
Frank
ORS
02-08-2007 15:14:43
 Re: rust in reply to F-I-T, 02-08-2007 10:58:26
very cool, speed secrets gotta love em thanks
F-I-T
02-08-2007 07:27:53
I sure favor electrolysis. I have used it for several years now, and I don't fire up my sand blaster anymore. I have an article that I wrote for a magazine a few years back posted on my website, along with a few pictures. It might be helpful.
BTW, it will work on ANY color tractor!
Frank
WEbsite: www.fboerger.com
mike a. tenn.
02-08-2007 02:53:50
hey "boy"..."electrolosis" is the way to go it sounds like. check back thru the "Ferguson Forums" from about last week or so...they just had a big discussion about it and you'll find websites for info and stuff. it's cheap and you can built it yourself...all you need is a plastic container and a battery charger. check it out, i'm getting ready to build one myself.
mike a. tenn
02-08-2007 03:11:03
 Re: rust in reply to mike a. tenn., 02-08-2007 02:53:50
.....carson, that's the "harry ferguson forum" you want to look thru. did you ever get your pistons freed up yet or are you still soakin' them? let us know how you're doing by posting updates on the tractor talk forum...i wanna keep tabs on how your project is coming along.
-mike
mike a. tenn.
02-08-2007 04:01:01
 Re: rust in reply to mike a. tenn, 02-08-2007 03:11:03
carson....look at today's posts in the "tool talk" forum about electrolisis.
-mike
