Applying Oliver Decals
Formerly PaMik
02-10-2007 09:20:12
I bought some decals for my 1755. Are there any tips on putting them on? I think I remember someone saying to make them wet so you can get them exactly where you want, and then when the water dries they will be stuck down. TIPS?
Thanks
AB
02-10-2007 22:31:48
 Re: Applying Oliver Decals in reply to Formerly PaMike, 02-10-2007 09:20:12
Link
glennster
02-10-2007 16:53:15
you can use soapy water in a pump spray bottle or go to a body shop suply store and buy the "special decal application potion" for about 30 dollars. figure out where you decals go, you can use masking tape to give you some reference points. lightly spray the area with your soap and water solution, apply decal, it will slide around a little on the soapy water. when you get it in place, use a rubber squeegee and start from the center and work out to push the water and air bubbles out. easy as pie!!!!
