glennster
02-15-2007 11:38:49
Re: buffing new and old paint in reply to glennster, 02-15-2007 11:17:14
ready to buff???? wash tractor with warm water with some car wash soap in it, get ALL the dirt and grit off. fill a 5 gal pail with warm water and car wash soap. get a big sponge, fold the 2000 grit paper two folds so its about the size of a cigarette pack. dunk the sponge in the water, dunk the sandpaper too. using the palm of your hand sand in one direction, use plenty of soapy water, also use the hose to flood the panel to flush away any grit. you want the panel to have an even dull haze. then wash and rinse the panel. if there is any exposed rubber gaskets or weatherstrips, tape them off, the ammonia in the compounds will stain them white. get buffer w coarse pad, put about a tablespoon of heavy compound on panel, fan buffer trigger, spread compound out about 16"square area, then buff, go up and down, move across the area, then go side to side, let the weight of the buffer do the work. buff up to and edges, not over them, the buffer can burn thru the paint. when done wash off compound, switch to polish pad, buff again. when done with that, clean the polish pad, switch to the #5 meguiars, buff for the last time. this will remove the swirl marks. of you have any questions, my email is always open.
