Supplied Air Hood Type???
mike6845
02-17-2007 15:59:42
First of all, thanks to Rod and all the others who have answered my previous question about supplied air systems. I am looking, like Bob with a B, at Turbine Products offerings, >Link
Now for the $64 question. what hood do I want? I will need hopefully only one and will use the system for painting with iso's, sandblasting and working in my dusty wood shop. I am leaning towards the sandblast hood system but need further convincing that it will protect me during my painting sessions. I am assuming that the paint hood offers more skin protection than the sandblaster hood, and will it really be worth it considering that I will not be painting very frequently or for long periods?
Brad_bb
02-21-2007 13:41:00
 Re: Supplied Air Hood Type??? in reply to mike6845, 02-17-2007 15:59:42
I already had a Stewart-Warner oil-less fresh air pump, the same supplied in the SAS fresh air systems. I then bought a Hobby air hood set up and connected them with a new high quality air hose and milton fittings. I like this set up alot. I wouldn"t mind a higher quality hood, but could not find one in my research. I may end up making my own some day, but that falls to the end of the list of things to do.
Bob with a B
02-18-2007 09:01:09
I am thinking of making a sandblast hood from an old welding helmet I have,one with the large size cover lens. Then closing in the back and the front and sides with a piece of heavy canvas. The lens would be protected by the replacable plastic cover lens for welding. Just use clear lens in the hood. not sure it will work out but out nothing but some time..... ..
CNKS
02-17-2007 18:49:18
I have two Hobby Air tyvec hoods, one for painting, one for sand blasting. The sand does not hurt the tyvec hood. But, I use my small blaster only with the item flat on the ground, and use an extension on the blasting wand to stay out of the line of fire. For a large commercial blaster, all bets are off. As the others said, don't use the paint hood for blasting.
Rod (NH)
02-17-2007 17:28:56
Mike,
I don't see how the paint hood would provide more skin protection than the blast hood. Anyway, I'd look to something other than the fresh air system for skin protection beyond the obvious face protection provided by any of the hoods. My concern with the blast hood would be the real possibility that the long "cape" would be hard to keep from getting onto the fresh paint. You'll have enough trouble dragging two hoses around w/o them getting tangled, or onto the paint. The occasional stepping on the air hose and having your breathing air cutoff momentarily is always a surprise distraction from concentrating on the actual painting process. You don't need still another distraction caused by the cape. One drag of that cape onto fresh paint and a mess will be had. I fail to see any big advantage of the cape that can't be accomplished in other ways, independent of the hood. My tendency would be to try and make either the bumpcap or the tyvek hood do double duty as a blast hood also, although I don't know about the longevity of the tyvek when used for blasting. No matter which hood you choose, make sure you get a plentiful supply of peel-off lens protectors. Sandblasting will destroy the visibility of an unprotected lens in no time at all.
Rod
B-maniac
02-17-2007 17:52:20
 Re: Supplied Air Hood Type??? in reply to Rod (NH), 02-17-2007 17:28:56
Not a good idea to use the same hood you blasted in when you go to paint. I don't think you would ever get ALL the dust particles out or off of it. You don't need that in your paint.
Rod (NH)
02-17-2007 18:10:17
 Re: Supplied Air Hood Type??? in reply to B-maniac, 02-17-2007 17:52:20
B---,
I don't disagree with you. It's always nice to have a dedicated tool for any particular task. However, that's not always feasible economically for most DIYs. I took the question to mean if only one hood was possible for both tasks, which one would it be? I wouldn't want to be painting with that cape dangling around. If cost is not a consideration, sure, get separate hoods - one for painting and the other for blasting. That would be the ideal situation.
Rod
