Re- Shoot
Dente
02-21-2007 12:53:53
Had a few runs in a paint job on an M. Sanded out the runs. Now to reshoot, do I just scotch bright the paint, mist a coat and reshoot a full wet coat or what? And does the whole part have to be done or will it blend in. Not sure of the procedure. Thanks
b-maniac
02-21-2007 15:25:06
 Re: Re- Shoot in reply to Dente, 02-21-2007 12:53:53
All depends on what type paint you used and whether you used a catylist or not. Anything with a catylist , you should be good to go after a month. Do it as you described. Uncatylized anything , give it 2 mos.,sand it all,then give it a week after you sanded it. Same method to spray. Assuming you are recoating with the SAME product as first paint job. You won't blend it in and have it not detectable if you are the least bit fussy. Some will call anything "good enough".
JRS
02-21-2007 13:56:14
Case, Are you saying the paint may wringle up on me If I re shoot it even if the paint has been dry for a month?
DurangoCase
02-21-2007 14:43:33
 Re: Re- Shoot in reply to JRS, 02-21-2007 13:56:14
Yes. Many, many variables, but a wet heavy coat of paint can even wrinkle cured paint. Semi-cured even easier. You really only get one shot from bare metal to get the paint on correctly. After that it's repaired paint.
DurangoCase
02-21-2007 13:35:55
May wrinkle if too wet of a coat, but wet enough to shine. Paint the whole part again or buff out the halo you leave.
