paint on stainless
jnewark
02-22-2007 04:04:40
greetings, I am in the process of building a 56 chevy for the play grease, we cut all the body parts on a plasma cam, welded em on a frame, and hung em on a golf cart,, my question is I will be spraying it this weekend,, the parts are 22 gage stainless steel,,, is there anything special I need to do?? thanks in advance
jack
Rod (NH)
02-22-2007 11:23:45
 Re: paint on stainless in reply to jnewark, 02-22-2007 04:04:40
Hi Jack,
For stainless steel, PPG recommends applying DX533 aluminum cleaner with a Scotch-Brite pad, followed by a rinse and an epoxy primer. If you want to save some money, I'd substitute PPG OMNI MP epoxy for the DPLF.
Why stainless though? Seems to be an unnecessary expense for what is essentially a prop.
third party image Rod
jnewark
02-23-2007 04:00:37
 Re: paint on stainless in reply to Rod (NH), 02-22-2007 11:23:45
the reason we used stainless... is we have a company which donated it... lots... and good stuff.. a little hard to work with but still worth it...
jack
ORS
02-22-2007 16:47:07
Let me just add to rods reply If you cannot find the Omni brand through your PPG jobber they may have switched to what PPG calls the Shop-line you will be looking MP375 it is about 25.00 a quart sprayable.It is the same as the OMNI just a different can. I believe the hardener is JH3770
