Min Painting Temp
Formerly PaMike
03-02-2007 09:33:27
I am spraying some U-Tech 3.8 Polyurathane. Its a 2 part paint. I sprayed all the small parts at work in the booth, but now I need to do the base tractor. I called the tech line and the minimum temp for painting they would recommend is 60 degrees. What temperatures have you guys sprayed at?Thanks
CNKS
03-02-2007 18:08:09
 Re: Min Painting Temp in reply to Formerly PaMike, 03-02-2007 09:33:27
65
djw
03-02-2007 17:58:13
Hi Mike, I paint a few tractors every winter in my garage. I have a torpedo heater and pretty much heat the tractor up till its hot to touch. No runs yet , and they turn out decent. Dave
Greg 77
03-02-2007 12:47:27
The lower the temperature the higher the risk of getting runs in your paint. Recoat timing is harder to calculate also. If you want do do a good error free job with no headaches, 60 degrees is the minimum temperature I would spray at.
