Painting 2150
Dente
03-14-2007 19:06:32
Was wondering if an activator and hardner can be used with I H 2150? Have an old M to paint. Usually use Dupont products and wonder what the results will be with the 2150. Now it is not quite the paint the Dupont is. With that paint I use the activator. Any ideas will be appreciated.
Mike S 806/H
03-17-2007 01:14:32
 Re: Painting 2150 in reply to Dente, 03-14-2007 19:06:32
With CaseIH 2150 use acrylic hardener and reducer I have used Omni, western, painters pride, and ppg brands of hardeners & reducers with 2150
CNKS
03-16-2007 18:04:09
Stick with DuPont -- the extra money is well worth it. Case-IH sells a hardener for 2150, also, but your dealer probably hasn't heard of it.
Circus
03-16-2007 07:16:53
 risky in reply to Dente, 03-14-2007 19:06:32
I have several shelves of half used hardeners. Painting is problematic at best. On the bright side goo doesn't chip.
TDK
03-14-2007 20:27:13
I've been using hardner from NAPA for acrylic enamel with 2150 for several years with good results. It's called "Acrylic Enamel Wet Look Hardner" # 15117. Dupont should have a similar product if you want to use their brand.
