preventing rust from forming
tractor Hank
03-16-2007 17:24:27
I am just starting to use electrolysis to clean parts and people recommend wiping it down with phosphoric acid afterwards to prevent rust and convert any that might be hiding. Where is the best place to buy phosphoric acid. I have not been able to find it. Thanks.
Mike S 806/H
03-18-2007 13:11:08
 Re: preventing rust from forming in reply to tractor Hank , 03-16-2007 17:24:27
go to Home depot its called (the must for rust)
treeman
03-18-2007 10:56:52
I was using "Ospho" until I tried "Right Stuff" which I buy frim Discount Auto. I like it better than Ospho and about half the cost.
Jim in OH
03-17-2007 19:01:29
What Rod has suggested is probably the best choice as it is prepared for the job, but the pure chemicals are available online from the experimental scientific community... example below.. and here Jim
Rod (NH)
03-17-2007 06:41:54
Hi,
There are many different proprietary formulations based on phosphoric acid and marketed under various brand names. Many require a water rinse after application. There are a few that do not. I like and use Picklex20. It can be applied to even sandblasted surfaces (most are not recomnmended for that) and does not require a water rinse. I have found it great to use if you have a rust free surface and cannot prime right away. Excellent protection. The part will stay rust-free for a long time. The product is pricey but is well worth it in my opinion. It will also remove light surface rust. Click to read the instructions:
third party image
It is available by mail-order here.
third party image Rod
MarkB_MI
03-17-2007 06:33:48
Check your local paint stores for "Ospho". If you can't get it locally, you can order it from Jamestown Distributors.
Circus
03-17-2007 06:11:39
Phosphoric acid is in milking equipment rinse but it doesn't give any protection against rust. At least the way I've been using it. Rinsing it off prior to drying.
