Paint type for farmall h
Farmall H Pulle
03-19-2007 14:48:44
Im am repainting my farmall h puller and have it all stripped down and sanded to bare metal. What I was wourding is what is the best looking and best brand of IH red to use.
Thank you, Miles
jason(ma)
03-20-2007 20:42:15
 Re: Paint type for farmall h in reply to Farmall H Puller, 03-19-2007 14:48:44
I'll add my $.02
like the others have said, the best paint depends on you,
The best paint for my antique tractors to ME is:
a single stage urethan from a major manufacture over the same major manufacture's epoxy primer as per that manufactures instructions.
what I happen to use on my last project a Allis G
was PPG. I was able to get the color I wanted in ppg easier than in dupont at that time. In the ppg I went with the more expensive concept line, I had better luck with the concept line over ppg's omni line. Omni works excellent for others, I am not a painter and feel it was more that particular color in omni than the Omni line being my problem. I like the urethans becuase they are durable and I can sand and buff out the crap that gets in my paint projects. I paint in a large garage and end up with dirt specs in my sheet metal. I have a fresh air mask to help protect me from the iso's. I have used and liked paint from Napa (sherman williams), Dupont and PPG. The only stuff I haven't liked has been CNH, John Deere and Tisco brands. Now I'm told CNH and John Deere have new paint now. Does that information help? Good luck
CNKS
03-20-2007 18:02:53
The factory color on your H was IH 50. Far as I know it must be mixed, not available premixed. IH 2150 which appeared in 1961 is the oldest red sold by Case-IH. Any other premixed brand is a crap shoot. Even 2150 is not the same color as the original 2150. As to quality, in increasing order: alkyd enamel, acrylic modified alkyd enamel, acrylic enamel, urethane.
B-maniac
03-19-2007 16:56:46
The word "best" is a very powerful word. It will/has caused some very heated "discussions" on these forums. I can tell you that "best" is very expensive , requires supplied air respirator , extensive training and more than likely is not really what you are really asking for. If you are asking what's best for YOUR particular application and use , which I believe you are , then you need to give us YOUR requirements of the finished paint job. Price , intended use , equipment to be used , intended spraying environment , skill level of person spraying , time line , finish longevity , etc,etc. They make so many diff. paints because there are so many diff. requirements. Be more specific and I believe you will then get the info you requested from many helpers on this forum. Thank you and good luck.
