SPOT PAINTING WORKED
JFAVOR
03-24-2007 21:28:43
third party image
The scotch pad worked great. Got rid of a lot of bumps and pits in the paint. I reshot the entire tank and grille. Any ideas on how to keep from scratching them when I put the hood on? Also; can I use the scotch pad before buffing or stick with 1500 sand paper? Thanks
beperson83
03-27-2007 09:37:44
 Re: SPOT PAINTING WORKED in reply to JFAVOR, 03-24-2007 21:28:43
Like circus said, dont use a scotch pad. Go with the 1500 or higher grade paper.
glennster
03-25-2007 17:03:59
use masking tapearound the edges when you put the sheetmetal on, use a regular autobody type tape so you dont pull any of the paint off. you can build up a few layers, then set the sheetmetal in place, then remove the tape. for added security, you can put some duct tape over the top of the masking tape.
JFAVOR
03-25-2007 20:42:51
 Re: SPOT PAINTING WORKED in reply to glennster, 03-25-2007 17:03:59
I used regular masking tape before (after I had already scratched it). Pulled some of the paint off. I have some of the blue tape now. I think it's supposed to be ok. I'll try some on the under side first.
circus
03-25-2007 05:44:51
 no in reply to JFAVOR, 03-24-2007 21:28:43
Don,t use scotch pad prior to polishing.The scratches are too deep.
