color sanding
MTC
03-30-2007 12:31:09
Hi-just painted a john deere with F&F enamel paint.Have a few minor paint flaws.Would like to color sand it.How long should I wait?Thanks Mike
treeman
03-31-2007 04:59:49
 Re: color sanding in reply to MTC, 03-30-2007 12:31:09
What is color sanding?
circus
03-31-2007 12:00:45
 swirl marks in reply to treeman, 03-31-2007 04:59:49
The drawback to sand & polish is visible swirl marks in the sun. Ultra fine $$$ sand paper, polish and glaze using wool and foam pads is the way to go. It may need glazing again in a few years. If this is done to soon after painting (jello), it'll dull after a day or so. Even worse it might roll off like a fruit rollup.
glennster
03-31-2007 07:46:37
 Re: color sanding in reply to treeman, 03-31-2007 04:59:49
after painting, there may be dust, orange peel (rough looking paint) or other minor imperfections. to remove them you water sand the new paint with fine grit wet cut sandpaper, generally 1500 to 2000 grit, sand the imperfections out , then using a buffer and compounds, polish the paint to a high gloss.
glennster
03-30-2007 12:53:21
to be on the safe side, if you used hardener, give it a week, if not i'd wait 3-4 weeks. get it out in the sun to help dry it.
