Case Primer ???????
Lenne
04-03-2007 18:15:02
Thinking of using the Case IH primer I have on hand. Wondering just how good a job it does against rust? I have wire wheeled the body of the M and removed all the heavy rust. If it will not do the job maybe I would then have to switch to the 2 part epoxy primer, pretty expensive. I was going to shoot the 34 P Dupont internation red. Thanks for any ideas.
CNKS
04-03-2007 18:53:05
 Re: Case Primer ??????? in reply to Lenne, 04-03-2007 18:15:02
34P?--the code for an M is IH 50/Dupont 7410. Use the primer recommended by DuPont. Epoxy is ok. It is also waterproof.
