W-6 Redo,
Kirk in Ks,
04-08-2007 07:25:48
Im hand sanding this W-6's fender's, and I wanna get them smooth, as well as the gas tank which has rust and scale all over it,
What's a good thing to use for the cast frame part to get the paint smooth, I cant do it with paper cause it's mostly rough, and it is pourus on the surface,
I could use a wire wheel to rough it up a little on the frame, Im doing this cause I cant get to the inside or underneath of tractor as i dont have a jack that heavy, to pull the back;'s off and lean them against something,
