rustyj14
04-16-2007 18:14:38
Re: Paint runs in reply to MTC, 04-12-2007 17:04:53
During my years of auto painting, i found, along with the preceding advice, that starting at the bottom of any flat vertical panel, will help to minimize runs and sags! Also, when spraying across the side door panels, stop spraying several inches from the edges, to minimize runs, and it will keep the paint coat more even. And, any inside curve should be sprayed less than the rest of the area. Especially if you are spraying other intersecting panels. Don't try to cover the primers in the first coats! The second coat should do that. I also pre-coated the inner door and panel edges, then closed the doors and lids on the first latch. Get some old doors or fenders from a body shop and practice painting them with them in their respective positions, not lying flat. I'll tell you-after spray painting hundreds of cars and trucks, and stretching my arms to clear the first coats, has made my arms much longer! the main thing that causes trouble in painting, is inexperience with the materials at hand, and inexperience with spray painting in general! It looks easy--it ain't! Only took me 6 years to finally learn it, but it was a case of do it, or else!
