used wrong paint color on ford mistake help please
pt756
04-12-2007 18:12:09
painted the sheet metal on 5600 ford never noticed till after we got done milking that the color sure looked darker than the casting that was already done, parts guy gave paint that was for the new holland fords, i sand blsated all old paint off then sandad some more, then used self-ecthing primer, then mixed up the wrong color with dupont 3812 and used 77s dupont as the hardener,went real good looked nice then clear coated with nason 497 really looked good then, can we just use a scuff pad or real fine grit paper? will it work with all the clear coat on? will it stick or do we have start all over again? it turned out really nice except it is the wrong shade, thank you for any advice or help
circus
04-13-2007 01:46:37
 Re: used wrong paint color on ford mistake help pl in reply to pt756, 04-12-2007 18:12:09
Sure, just scuff and paint. Your fortunate, sheet metal is easier than cast to scuff. The only question is, is the color coat designed to be cleared?
