54 Ferguson-runs strong, but won't start unless pulled.
Paul Sansaver
05-08-2002 16:08:48
I broke the exhaust manifold last fall. With a temporary fix it was noisy but worked well. Then it started missing and losing power. Parked it for the winter. Had the manifold replaced this spring(?its been snowing all day), installed carburetor kit and new plugs. Started several times at the mechinics garage. Loaded it and took it home and it wouldn't start. Pull it and it starts in about 10 feet and runs well and strong. Took it back to the mechanic and they can't get it to start. Anyone have any ideas?
roy
05-09-2002 18:26:44
 Re: 54 Ferguson-runs strong, but won't start unless pulled. in reply to Paul Sansaver, 05-08-2002 16:08:48
check out the coil
Paul Sansaver
05-13-2002 13:26:07
 Re: Re: 54 Ferguson-runs strong, but won't start unless pulled. in reply to roy, 05-09-2002 18:26:44
Roy-new coil, points, plugs,manifold and carb kit. Still wouldn't start. Have you ever heard the starter button could be bad? Heard that from someone this last weekend. Mechanics are still searching.
Paul
kjm
06-07-2002 10:00:54
 Re: Re: Re: 54 Ferguson-runs strong, but won't start unless pulled. in reply to Paul Sansaver, 05-13-2002 13:26:07
check the reistor. Sounds like an old Dodge I had
