Hi Bruce, Anything is possible. Even no respirator at all. But it's generally not recommended. I'll add another "IF" to CNKS's post. I know of no cartridge respirator manufacturer who recommends their product for use with isocyanates where the airborne concentration is unknown. That's usually the case in all DIY work. For example, 3M does recommend one of their organic vapor cartridges (when also used with a particulate prefilter) for isocyanates - but only up to an airborne concentration of 0.05 ppm, regardless of how fresh the cartridge is. Of course all other aspects, such as those CNKS indicates, must also be met. That means no facial hair for one thing and required fit testing. If the concentration is not known, then 3M recommends supplied-air, period. The National Institute of Occupational Safety and Health (NIOSH) recommends supplied-air for all exposure to isocyanates, no matter the concentration level. The fine print from either PPG or DuPont also leads to supplied-air, as does a wealth of other authoritative sources, some of which are legally binding in their jurisdiction. For DIYs though, it is a personal safety decision. They should make an informed one. The risk is theirs to take. Some seem to ignore the warnings and have apparently been able to get away with it. Others have not. I'm a typical backyard DIY and I went to supplied-air many years ago because of a bad experience with isocyanates in acrylic enamel hardener. I do not recommend a cartridge type of respirator when painting with materials containing isocyanates - even when done outside. I don't do it myself and I don't recommend it to others. The cost of the equipment is not great at all if you put any significant value on your own respiratory health. You might want to investigate DuPont's NASON Fast-Dry acrylic enamel in addition to the PPG OMNI acrylic enamel mentioned. That should be comparably priced and can be used w/o a hardener additive. I have not used it myself. Either of those will be a lot lower in cost than the PPG DCC you were quoted. You might also look into the industrial/commercial lines of either DuPont or PPG. There are opportunities there for good, economical choices, depending on local availability and color selection. Look for either acrylic enamel or acrylic modified alkyd enamel. Other than that, you are pretty much left with the old chemistry alkyd enamels sold in tractor supply stores, hardware stores and home centers. Rod
