Help in painting a old plow ??
Earl-IL
04-25-2007 13:45:29
I need to paint a rusty old plow . What is the best way to prep it other than Sand Blasting. Thanks Earl
glennster
04-27-2007 06:07:32
 Re: Help in painting a old plow ?? in reply to Earl-IL, 04-25-2007 13:45:29
i just fixed a flat on the back tire of an m. rim was rusted pretty good. i used a wire brush wheel on a grinder, cleaned it up best as i could, then used 2 coats of por-15 rust converter. brushed it on. came out pretty good, the por 15 filled a lot of the little pot holes in the metal.that may work good for your plow, you do need to put paint over the top of por 15 tho.
Earl-IL
04-27-2007 18:22:31
 Re: Help in painting a old plow ?? in reply to glennster, 04-27-2007 06:07:32
Thanks for the reply. Earl
soundguy
04-25-2007 17:48:21
Sandblasting would probably be the 'catch all'.. however.. depending on the condition.. anything from a wire wheel to sandpaper -will- work.
You can also prime with a rust control or etching primer.. etc..
Soundguy
Earl-IL
04-27-2007 18:23:26
 Re: Help in painting a old plow ?? in reply to soundguy, 04-25-2007 17:48:21
