Thinner for Polyurethane
stan2270
04-30-2007 05:10:21
I amusing LIC (Valspar)activated epoxy primers and polyurethane top coats. Cleanup is specified as Valspar 100 thinner. I tried regular paint thinner but it was incompatible. Is there a generic brand of compatible thinner that anyone can recommend and where to buy? Thanks
ORS
05-02-2007 03:55:18
 Re: Thinner for Polyurethane in reply to stan2270, 04-30-2007 05:10:21
Carquest sells a laquer thinner that is cheap, I believe part # WT10 (Western) is what you are looking for. 5 gallons should cost you about $35-$40 bucks.
B-maniac
04-30-2007 18:00:38
I havn't found any that good ole laquer thinner won't cut! Too expensive and a waste to use urethane reducer to clean equipment. Buy the economy laquer thinner as it will clean it up fine.
