What color should i paint my JD 60 rear axles
630man
05-14-2007 18:17:51
I am restoring a John Deere 60 and I was wondering what color I should paint my rear axles or should I leave them bare metal. Any thoughts would be great. Thanks in advance John
HAPPY DEERE
05-18-2007 18:44:37
 Re: What color should i paint my JD 60 rear axles in reply to 630man, 05-14-2007 18:17:51
bare metal rub light grease on them
B-maniac
05-18-2007 18:58:27
 Re: What color should i paint my JD 60 rear axles in reply to HAPPY DEERE, 05-18-2007 18:44:37
You can also clean to bare metal and then clear coat them. Better than grease and looks better than black paint.
n8terry
05-16-2007 08:19:03
Its probably a safe bet that the only paint that got on the axles at the factory was over spray of the green or the yellow, or both!
Personally, I would leave them the bare metal after cleaning them up using fine sand paper. If the tractor is going to sit outside a lot or you live where there is high humidity, then I would be tempted to paint them black.
The farmall guy confused me when I tried to understand what he was talking about! I guess I am not very smart.
Farmall MD nut
05-16-2007 15:43:20
 Re: What color should i paint my JD 60 rear axles in reply to n8terry, 05-16-2007 08:19:03
Yeah, sorry, that was my fault. I was thinking of something totaly different.
Farmall MD nut
05-15-2007 16:40:40
Do you mean the part Of the axles that are in the housing, or the part that you can see(the hub of the axle)?
