repaint
Mike Cummings
05-19-2007 12:23:40
Hi guys-I painted a home built tractor with Valspar oil base paint with hardener and do not like the color.I want to repaint it with a darker color.How long do I have to wait?Thanks
CNKS
05-20-2007 17:48:24
 Re: repaint in reply to Mike Cummings, 05-19-2007 12:23:40
Probably any time, be sure to scuff it first. Some paints have a window in which they can be repainted without preparation, I don't know what Valspar's is. If your paint was fully cured, you could seal it and use about anything. Since it probably isn't, you should probably use more of the same type paint. Others may have other opinions.
Mike Cummings
05-19-2007 13:36:58
One more question-what other paint can I use over this Valspar paint?Thanks
john_bud
05-22-2007 20:23:40
 Re: repaint in reply to Mike Cummings, 05-19-2007 13:36:58
If it was painted very recently, you may be able to just spray a mist coat then a full coat over it with no other prep. Otherwise you need to wait for full cure and then scuff sand it.
I would stick with the same paint, but get the color you want. Much less worry.
jb
B-maniac
05-22-2007 17:26:13
Give it at least a month. Stay with same brand. Scotchbrite for adhesion. This time SPRAY A TEST PANEL BEFORE you do the unit!!! MURPHY'S LAW is alive and thriving in the paint bussiness!!!
