Lacquer primer
jasman
05-17-2002 13:42:21
Is lacquer based sanding primer compatable with enamel paint?
CNKS
05-17-2002 18:50:36
 Re: Lacquer primer in reply to jasman, 05-17-2002 13:42:21
Probably not. But, read what it says on the can -- should tell you what you can topcoat with.
ret
05-17-2002 19:01:10
 Re: Re: Lacquer primer in reply to CNKS, 05-17-2002 18:50:36
Lacquer primer or paint over an enamel finish with probably lift it real quick. You can put enamel over lacquer, but not the other way around. Sometimes, if you use a fast enough thinner, it may not lift, but then you are sacrificing its ability to adhere properly take some thinner on a rag and try it in an out of the way place. Good luck
