 I'm "overhauling" a D-65 pedal tractor for grandson #1. It looks bad, but there are no cracks in the castings, so it 's a good restoration candidate. It has been painted with Oliver Green brushed on enamel, some sort of white stuff that I can hardly get to lift, and for you Farmall fans, there's even some red paint on the axle housings. If it was steel or iron, it would be in my electrolysis tank, or at least getting the lye gravy treatment, but being aluminum, I can't go caustic for fear that the base metal will pit. I normally use something with a lot of Methylene Chloride in it like Zip-Strip, but after half a gallon, it's coming off, but very slowly and it really needs coaxing off using a small wire brush. It just gets gummy and sort of rolls off. At this rate, I will get it cleaned, but I was wondering if anyone out there had another product to suggest. I don't want to hit it with my sandblaster, as I feel you lose too much detail that way with the eroding of the soft metal, and if it were to be blasted, it really should be with plastic media. Used to be you could find aircraft stripping products out there with Butyl Alcohol in them, which I would go to when up against an epoxy, which I think that white stuff may be, but I have not been successful finding any. They probably went the way of Phisohex. I might even try some Methyl Ethyl Ketone to see if it will lift it and flush the surface clean. Appreciate any leads. Oh, and what do you use for a primer for aluminum? Is a traditional DP-40/90 all right? I would like to finish it with my traditional acrylic enamel, wet sand, clear coat method, or I might opt for a base coat/clear coat, but I need a primer that will stick and be tough enough for the kid to knock it around. Frank
