TSC paint dry cure times
aju
06-16-2007 14:14:40
How long does TSC paint typically take to dry and cure???(with hardener) I painted yesterday and the paint dried to touch in about 6-7 hours but its still soft after 24hrs(will scrape with fingernail)
It about 85 degrees here. Is there a problem?
Thanks
bassndeere
07-01-2007 18:24:57
 Re: TSC paint dry cure times in reply to aju, 06-16-2007 14:14:40
Cure time isn't important now. Durability is. When you repaint it next year, use better paint. Or keep it in the shed out of the sun. TSC paint has no UV protection. Fades or changes color in about a year of good sunlight.
glennster
06-17-2007 15:14:20
should be good and hard in about a week, get it out in the sun if you can. depends a lot on the humidity too, high humidity gives a slower dry time. with the temps you have in the 80's, maybe turn on a fan to get the air moving arund in the shop, that will help the reducers/thinners flash off.
