Hi, The 8022S is a DuPont Centari (acrylic enamel) reducer. If you recall using that reducer on your van, then the paint was very likely Centari. That's a top notch acrylic enamel (single stage). If you are completely satisfied with that, then go ahead and use it. If you do, I recommend using it with the ultra performance pak field mix. There are now three different field mixes for Centari; a standard non-iso, unhardened mix called Ultra 1K pak acrylic enamel, a conventional hardened acrylic enamel using 793S hardener (iso) and the Utra Performance Pak (iso) classed as an acrylic urethane. I'll agree with CNKS about the PPG OMNI MTK acrylic urethane. I think it provides the best performance for the buck in a single stage paint, even being less costly than Centari. But you can't go wrong with the Centari either. It's very easy to apply, covers excellent, plus it will go over the MP170 epoxy fine, even though it is in a different product line from a different manufacturer. As far as the exact shade goes, I can't help because I am not familiar with the JD colors or the available codes. The best I can advise is to purchase small quantities of several promising codes and verify your preference before spending much. For some PPG codes, see here. For some DuPont codes, see here. Unless you are using a metallic color, I see no compelling reason to go with a two stage base/clear system unless you want to. Since you have experience spraying both systems, it's your personal preference which you use. PPG OMNI makes a companion basecoat for two stage systems in the same colors as the MTK. Chromabase is the premium basecoat in DuPont. For something in DuPont, but more in line with the cost of the OMNI products, look into DuPont's NASON line. They have both single and two stage products in that line. As CNKS indicates, respiratory safety dictates supplied-air equipment when using hardeners containing isocyanates - even when painting outside. Some disagree with that. But it's their responsibility for a personal decision to ignore the fine print from the manufacturers and regulatory safety agencies. I've been personally affected by isos twice in the distant past w/o supplied-air and decided that there would never be a third time. And there hasn't been in about 30 years of using hardeners w/supplied-air on DIY projects, mostly outside. Rod
