6 foot tube cleaning
Big Hunter
06-28-2007 00:43:29
I have a 6 foot by 3 inch diameter pipe that goes from the air cleaner to the turbo. It's pretty much straight other then at on end it has a 180 degree sweep at about a 8 inch radius...anyhow inside the pipe is some rust, how do I clean that out, electrolysis? and then how and with what do I coat the inside? remember it goes straight to the turbo, can't have anything peeling, flaking off later on. Maybe I should just go and get a stainless steel or alum. pipe made up? (how the heck do you spell aluminuim...bahahaha)
souNdguy
06-28-2007 12:23:40
 Re: 6 foot tube cleaning in reply to Big Hunter, 06-28-2007 00:43:29
Phosphoric acid will eat the rust..
I guess you could then coat it with a feul tank liner epoxy if ya needed to.
POR15 might be the trick .. get it catalized etc..
Soundguy
