What type of filler to use
Dalton S.
07-13-2007 18:21:53
What do I use to fill in rusted out places on sheet metal? Any advice is greatly appreciated.
circus
07-16-2007 10:28:11
 Re: What type of filler to use in reply to Dalton S., 07-13-2007 18:21:53
It's not as important what you use as how it's used. If both sides of the hole is cleaned of rust and sealed, the patch will last a long time. If only the outside is patched or filled. It'll bubble faster than you can sell it.
B-maniac
07-13-2007 19:28:21
You need to first cut out the rust back to good solid metal and weld in a new section , grind your welds flat and then any name brand filler will work to smooth it out. Any lesser method won't last very long on a viberating tractor's sheet metal parts.
