PPG OMNI for MM 4 Star, M5, GVI
rvirgil_ks
07-20-2007 06:35:04
Can anyone tell me the color codes for PPG OMNI paint for Minneapolis Moline 4 Star, M5, GVI tractors? I need both the Power Yellow/Prairie Gold #3 and the Metallic Brown/Bronze Metallic
Thanks, Bob
PhilC
07-22-2007 14:51:38
 Re: PPG OMNI for MM 4 Star, M5, GVI in reply to rvirgil_ks, 07-20-2007 06:35:04
Glen is right, take a small part painted the color you want duplicated. Most paint supply stores have scanners they use to read the color on the part and then create the color you want. If it's already in their formula database, they'll mix it up and provide the current info (Ford, GM, Chrysler, etc.). If not, they'll custom mix it for you, but it will cost more that way.
GlenIdaho
07-21-2007 06:58:18
Courtesy of Rod NH, these are the PPG paint codes.
Caution: This list was assembled using three different PPG sources plus input from others. There was no information concerning model or year, except as noted. Use this list at your own risk. There are no guarantees. I have only confirmed the AC early persian orange, sometimes referred to as "persian #1", as 60080. Most of the codes should be available in most, if not all, current PPG automotive paint chemistries, including the economy OMNI line. See your local PPG jobber for details. I strongly suggest first purchasing the smallest possible quantity in an attempt to verify the proper shade. Custom mixed colors are not returnable. Unfortunately, whenever a color proper name has multiple codes listed against it, I have no idea which one is appropriate for your application. If you are particular about shade, you may have to sample them all. If you wish to get information on the different chemistries available from PPG, including technical data sheets (detailed usage info) and material safety data sheets (MSDS=safety & health info), go to the PPG website.
Minneapolis Moline Dyna Brown----- ----- --22394
Minneapolis Moline Dyna Brown #2 (1967)----23049
Minneapolis Moline Orange----- ----- ----- 60740
Minneapolis Moline Prairie Gold----- ----- 60098
Minneapolis Moline Prairie Gold #2----- ---60039
Minneapolis Moline Red----- ----- ----- ---71528
Minneapolis Moline Red----- ----- ----- ---70385
rvirgil_ks
07-21-2007 19:56:20
 Re: PPG OMNI for MM 4 Star, M5, GVI in reply to GlenIdaho, 07-21-2007 06:58:18
I appreciate the reply. I have this listing. I was wondering if the Minneapolis Moline Orange #60740 might be close to Prairie Gold #3/Power yellow.
I ordered a quart of it and was told it was a yellow-orange color. When it came it was labeled as a Chrysler color. It is close to Prairie Gold #2, but is a bit lighter, less orange and more toward yellow. It would work for Prairie Gold on something where close would be good enough, but I wouldn't put it on a tractor at this point.
I've searched all over for the PPG mix number for prairie gold #3/Power Yellow and Metallic brown/Bronze Metallic but so far no success.
We have used PPG OMNI and are pleased with the results.
Thanks for your reply, Bob
GlenIdaho
07-22-2007 13:12:25
 Re: PPG OMNI for MM 4 Star, M5, GVI in reply to rvirgil_ks, 07-21-2007 19:56:20
I don't know if this will help, but if you can find a paint sample of the color you want, you can take it to the paint store and they can do a good job matching the color. I did this with a Ford color and it turned out identical.
