Paint gun spitting
Mtc
07-24-2007 17:07:32
Hi guys-painted a allis G to day.The paint gun was spitting paint.I thought I had everything adjusted right.Now I have a couple clumps in my paint job.Guess I will sand them out and give it another light coat.Good idea?Thanks
hunting4junk
07-26-2007 10:40:00
 Re: Paint gun spitting in reply to Mtc, 07-24-2007 17:07:32
along with everything else mentioned not getting it cleaned properly last time and also contamination in the paint that wasn't strained out prior to pouring in the cup can also cause sputtering.
Matt Weltz
07-26-2007 10:30:28
I have had this problem from time to time too. Either all pieces of the gun are not tightened down enough and are letting air in, or the pait is not thin enough. Check all the fittings and if it still does it, use more thinner in you paint.
circus
07-26-2007 04:56:45
Lose or dry packing behind the spray head, allowing air in, will cause sputtering.
5020s rock
07-25-2007 01:42:28
dude--read the post down further. i am dealing with the same conditions. the pressure,
the viscosity, the length of hose--ALL MAKE A DIFFERENCE. i call "globs" orange peel. oh--the speed and distance away from the work
are critical too. bye
IH RED
08-09-2007 22:40:45
 Re: Paint gun spitting in reply to 5020s rock, 07-25-2007 01:42:28
speed and distance can casue some vary but depends on how u paint if i paint single stage i back up and go over it slow... when i paint b/c i spray close and lay then hammer down when i paint....no problems yet...
Larry806
07-24-2007 18:42:30
What kinda gun?
On the guns I've used the mixing valve wasn't tight enough when they did that .
Rexalot
07-25-2007 12:53:20
 Re: Paint gun spitting in reply to Larry806, 07-24-2007 18:42:30
Suction gun? Vent in top of can may be plugged...
Rustyj14.
08-03-2007 14:21:02
 Re: Paint gun spitting in reply to Rexalot, 07-25-2007 12:53:20
The packing in the forward section of the paint gun--where the needle goes into it, must be lubricated occasionally. I always used a drop of motor oil, and allowed it to sink in, then wiped off the rest. working the trigger helped the oil to get into the packing. Never had any problem with it getting in the paint, and usually lasted for 3-4 months.
