rust
donaldl
07-28-2007 05:01:28
what your thinking of Rust Convertor
CNKS
07-28-2007 13:23:08
 Re: rust in reply to donaldl, 07-28-2007 05:01:28
If you are able to remove all the rust do so. If you have a complex implement, etc that is impractical to sandblast, wire wheel or sand, use rust converter. I mechanically remove rust whenever it is feasible, which for me is 99% of the time.
GeneMO
08-14-2007 04:43:22
 Re: rust in reply to CNKS, 07-28-2007 13:23:08
Look in the archives for "Electrolysis" Hope I spelled that right! If you have the desire to build a set up, I find this method very good at disolving rust. Of course it has to be a part that will fit in the electrolysis tank, generally a 55 gallon plastic drum. Depending on how much current you can run through the part, it takes 2-4 days, also depends on how rusted the part is.
Gene
