Removing paint from nooks crannies
Dukester
08-12-2007 14:58:53
What's the best tool / technique for getting several layers of paint from tight places like behind nuts and corners etc.? Right now I'm using stripper and then scraping, wire brush, wire wheel but most of these things like wire wheel is too large to fit into small places. Is there an easy way?
bill mar
08-20-2007 16:50:58
 Re: Removing paint from nooks crannies in reply to Dukester, 08-12-2007 14:58:53
take this for what its worth ,but on non-flammable areas/items ive used my torch to burn it off keeping in mind to not get the metal hot enough to warp it.I use this method alot on rims that i siphon sandblasted (dont own a pressure blaster)and there are specks of paint that the blaster didnt remove.
CNKS
08-12-2007 17:23:46
Needle scaler -- Do a Google, etc search for availability. Use only on cast, it will damage sheet metal.
