ELECTROLYSIS
LEWIS
10-21-2001 13:17:33
IS ANYONE USING THE ELECTROLYSIS PROCESS TO PREPARE THEIR OLD TRACTORS FOR PAINTING? I HAVE TRIED IT ON SMALL PARTS AND IT SEEMS TO WORK. ANY INFO. ON THE PROCESS WOULD BE HELPFUL.
Gene Davis
10-22-2001 22:27:30
 Re: ELECTROLYSIS in reply to LEWIS, 10-21-2001 13:17:33
I have used it on a few small parts, and it did a fairly good job, intend to increase the size of the container, and use a bigger charger and see if it will speed it up.
Gene Davis
Bill L
11-04-2001 04:06:53
 Re: Re: ELECTROLYSIS in reply to Gene Davis, 10-22-2001 22:27:30
Used a a battery charger for a while Now I use my mig welder. Puts out DC and can be adjusted.
Read the posts below
10-21-2001 15:00:24
See - question for Franz.
Richard
10-23-2001 11:00:53
 Re: Re: ELECTROLYSIS in reply to Read the posts below, 10-21-2001 15:00:24
Will the solution freeze in the winter?
Franz
10-23-2001 18:16:28
 Re: Re: Re: ELECTROLYSIS in reply to Richard , 10-23-2001 11:00:53
The frezing point is around 18 to 20 degrees farenheight, slightly lower if you are running current thru it.
LEWIS
10-23-2001 17:44:41
I'M PRETTY SURE IT WILL FREEZE AS IT IS JUST WATER AND WASHING DETERGENT. AN ADDED NOTE, A GOLF-CART BATTERY CHARGER WORKS EVEN BETTER THAN AN AUTOMOTIVE TYPE. SLIGHTLY HIGHER VOLTAGE AND AMPERAGE.
Jone
10-25-2001 15:21:32
 Re: Re: Re: Re: ELECTROLYSIS in reply to LEWIS, 10-23-2001 17:44:41
This method works great!!!
Iv used it on my Ferguson 1950 TEA and it was mutch eseyer, and healhier than using an angle grinder(a lot of dust you know), only I used Caustical Soda (LYE), thats the quikest method, to get the old crap off, it takes paint and grease as well as rust.
