Proper paint for a Ford 3000
Frank Kaufman (
08-30-2007 15:45:05
I'm going to strip my 1970 Ford 3000 and repaint. What would be the best choice for painting the sheet metal and the rest of the tractor? I only want to do this once, so I want a paint that will hold up to normal use and not peel within a few years. Thanks in advance.
B-maniac
08-31-2007 19:27:22
 Re: Proper paint for a Ford 3000 in reply to Frank Kaufman (Ky), 08-30-2007 15:45:05
Talk with an auto supply store that also supplies local body shops and is conveniant to you. Use the complete "system" that the paint technology you choose calls for. You said "best". You will get a million answers on here to that request. MOST paint problems are NOT caused by inferior paint products but in fact are caused by mixing different product lines and their procedures and then not even following them and taking "short cuts". It may not be low cost to use such a system but it will be very expensive and dissapointing and maybe even embarrassing not to. Good luck with your ford.
