simple paint
Pat-CT
08-30-2007 19:52:39
if i use spray primer and rattle can paint for my farmall will it still have a glossy finish i ask this becuase i dont really have time to use a gun and its just for the frame i already painted the hoods and gas tank right but i just want it to look better then the roll on paint it has now or better yet even can i use a spray primer then dont paint for a couple days this way i can just paint the whole frame and rear end at once or does paint have to go on imeditly after primer sorry if im not knowing but this is my frist tractor for 1 and the first time painting so thanks for your time-PAT
Bob with a 60
09-05-2007 06:34:50
 Re: simple paint in reply to Pat-CT, 08-30-2007 19:52:39
Prob with rattle can paint fading faster I think is because it is thinned so much. Instuctions on paint you mix usually says that if thinned beyond the manufacturers recommendations you will lose luster and durability.
44 massey
09-01-2007 08:33:41
My experience with rattle can paint is that it has the nice glossy appearance but it sure dosent last as long as sprayed painted, starts fadding a lot faster!!
B-maniac
08-31-2007 19:15:53
I would go ahead as you have planned. At the level of technology that you are useing,it is always an experiment. Prime the whole thing and just before you paint just hit it lightly with a scotch brite pad that you can get at any auto supply store.Don't sweat the spots you can't get. It isn't like the paint is just gonna fall off. Paint doesn't just fall off,it is usually knocked off. Yes it will "knock" off easier without adhesion it sounds like for your intended use you won't see the difference. Do it the way it works best for you. It's not a restoration.
