towing
bob barnes
09-09-2007 15:17:47
does any one know if you can tow a tractor with a tow bar for a short distance sometimes its hard to rent a trailer ???
glennster
09-12-2007 13:13:14
 Re: towing in reply to bob barnes, 09-09-2007 15:17:47
i tow my m occasionally behind my pickup. i have a towbar made from an old wagon tongue. it bolts to two ears on the front lower bolster, and its hinged. i dont tow over 10 miles an hour. tractor has the bush hog on the back, and i mow at the other farm about 6 miles away. that way i have the truck there in case i break down, get stuck, or get a flat.
SDE
09-11-2007 16:57:49
I had intended to buy a tractor last friday and tow it home. It would have been about 40 miles. I took an air compressor and ten gallons of Hytran with me. I did not get it.
The only suggestion I recieved about my post, was not to go faster than the tractor was designed to operate at.
SDE
bob barnes
09-11-2007 19:12:24
 Re: towing in reply to SDE, 09-11-2007 16:57:49
im thinking of towing it backward using a standard tow bar with the bumper clamps removed and hooking it to the draw bar ???sound ok bob
Dick Wimer
10-08-2007 17:17:08
 Re: towing in reply to bob barnes, 09-11-2007 19:12:24
Backwards? How do you plan to make any turns? Let me know where you are going so I can stay out of the way. Good luck with your tow, do it from the front!
patsdeere
09-11-2007 10:30:37
First off I think that this post belongs in another section, but oh well.
In regards to towing, it will depend on the tractor. I have heard of issues when trying to tow JDs, but have seen an oliver towed about 10 miles with no obvious problems.
