bondo and rust convertor
SDE
09-11-2007 16:48:53
My panels had a black stain under the old paint. I believe it is a type of corrosion. Do you treat the corrosion first and then put bondo in the dents? Do you treat the corrsion and then sand the metal back down to a clean metal surface again before filling the dents? I used the Permatex brand of convertor and the panels have turned a black color. Should I sand them before appling the Epoxy Primer?
Thank you SDE
SDE
09-11-2007 17:14:22
 Re: bondo and rust convertor in reply to SDE, 09-11-2007 16:48:53
The ? was asked and answered about 1/2 page down.
Thank you SDE
