How do you get tires clean?
Kent in KC
09-14-2007 13:56:51
Before you go to the fall parade, how do you get the mud and clay stains off your tires? I've tried the power washer with detergent and a wire brush. They still look grungy. I've seen some guys tractors look like they have new tires but they're not.
Daniel H.
12-21-2007 17:18:10
 Re: How do you get tires clean? in reply to Kent in KC, 09-14-2007 13:56:51
ME Miller black tire paint is the best thing I have used. A quart will go a long way since you mix it with water. I put it on with an old brush, and the tires look new.
Link
Look under repair/supplies
47_A_puller
12-09-2007 01:20:09
try some stuff called purple power it works great at bringing stains out of tires
Joe Novak
09-24-2007 10:04:08
Try a product called Tire Bleach made by Wesleys, spray it on, scrub tire with a stiff bristled brush, rinse off, repeat if necessary. It cleans the dirtiest tires very well with minimal effort and the tires appear like new without the greasy wet look of other tire dressings. Most parts stores sell it as does Sams Club.
jubilee johnny
09-20-2007 08:56:45
If you have pressure washed the tires and they are still stained use a rag soaked with laquer thinner. I have found this to bring the black out before using the tire foam. After that, the foam keeps the tires from getting as much stain. Just my experience.
Mike M
09-18-2007 13:05:57
Driving around in the snow cleans them very well too.
PhilC
09-16-2007 19:49:58
Jeff Mans said: Just dont use it around the paintshop, you"ll have more fish eyes than the Pacific ocean
ROTFLMAO!third party imageThat holds true for most any tire dressing product!
Kent in KC
09-15-2007 06:03:50
Thanks guys. Pretty tractor, Glennster.
soundguy
09-14-2007 22:25:17
Ditto on the Spray foam tire products.. and they also make a tire paint too!
Soundguy
B-maniac
09-14-2007 19:02:34
I agree 100% with glenster. Armorall Tire Foam. It gives them a "naturally new" look and not that wet plastic look like a lot of other products.
Jeff Mans
09-16-2007 06:41:38
 Re: How do you get tires clean? in reply to B-maniac, 09-14-2007 19:02:34
glennster
09-14-2007 14:34:56
i use armour all tire foam. comes in a spray can, you spray it on, and leave it. the dirt flows off and it leaves a nice shine. any similiar type product will work the same. if the tires are really bad, scrub them first with castrol super clean and a stiff bristle brush, rinse well with water then spray on the tire cleaner.
it even cleans up the tires on the hay rack
third party image
Paul from MN
09-18-2007 12:05:21
 Re: How do you get tires clean? in reply to glennster, 09-14-2007 14:34:56
I also use Tire Foam. HOWEVER.... Be extremely careful if you are going to be putting the tractor on a trailer. The stuff can make the tires slippery. I figured it would be OK if I put the tire foam on a couple weeks before. Turned out I was wrong. I load two narrow front tractors on my trailer, backing one on and offsetting it from the other that I drive on. The tractor that gets backed on has one rear tire near the edge of the trailer. With the tire foam when I went to stop, the tractor kept on sliding... It did not go over the edge, but got a lot closer than I ever want to get again.
I like the stuff enough to keep using it. But from now on, i'll put it on once a year after the show season to give it time dry up and wear off before I load. The tires won't be as black, but they will look nice and I'll be safer.
