U-tech paint
Frank from Ky.
09-25-2007 20:59:30
Anyone have any experience with U-tech 200 paint?
Someone told me it was a good urethane paint for tractors. Any special techiques associated with this system?
Johnsdeere
10-18-2007 15:11:04
 Re: U-tech paint in reply to Frank from Ky., 09-25-2007 20:59:30
Nice paint, I have used it,and like it, I would recommend this for DIY users. very user friendly, run resistant and priced reasonable. They also have a clear coat you can put in your final coat if thats what you like. Its designed to be sprayed in open shop environments. I made the error of ordering a gallon of paint the first tractor I used it on since I had been using Omni MTK. But even though Utech was a litte more expensive, It only took 2 quarts compared to 1 gallon. Red covered in 2 coats over grey and laid really flat. I really like Utech 3.5, I Painted a Ford Taurus complete in Coke red the most expensive paint code they have just so happen, I put one coat of E350 grey epoxy on it as a epoxy sealer, waited for it too flash for 25 min and sprayed the 3.5 polyurethane over it, 3.5 is a single pass product you put on 1 1/2 coats. One wet coat and spary it with a cross coat the other direction to make sure you have coverage even. It took me 1 quart of paint and one quart of epoxy. Total job was 124.50, it had gloss as high as any clear coat on the market. BTW I did another Taurus with Utech Poly Base Plus Base coat Clear coat, put one coat of sealer on it, 1.5 coats of base and 1.5 coats of clear on it. The base and clear is designed to cover in 1 coat and still has the mills required. this job cost me 196.00 total for the complete. Turned out great. My next Tractor JD 4430 I am doing I will do the hood and side panels in BC/CC and the rest in 3.5 Utech. I cant believe the coverage of of their paint.
