Primers
John Knipfer
10-08-2007 18:02:31
This message is a reply to an archived post by Rod NH on July 08, 2005 at 17:20:23.
The original subject was "Re: Primers".
I used PPG DPLF Non-Sanding on a car I was refinishing.The breaker threw and i did notice and as I sprayed(outside) my air pressure went down thus started to spit a little.Is there harm in sanding?Thanks!John
Johnsdeere
10-18-2007 14:34:31
 Re: Primers in reply to John Knipfer, 10-08-2007 18:02:31
Epoxy by nature is tough to sand but can be done. The other problem with Epoxy is that it is slow drying. Nothing beats Epoxy for rust protection on a restoration. Make sure you watch the recoat window or you must sand it or scuff it before top coating. Always ask you paint supplier to give you a tech sheet when you buy products.
B-maniac
10-08-2007 18:07:53
No there is no harm in sanding as long as it has dried for at least 4 or 5 hrs. Don't dry sand. Use 600 grit and a little water. You may have to re-coat the area if you go through to metal.
