There's a book at the bookstore "How to paint your car" that lays out the basics pretty well for someone doing it in a diy environment as opposed to a pro paint booth. Ditto everything CNKS said. On your gun, I would suggest an HVLP unit to reduce overspray and for economy (more paint on the tractor instead of the floor). My best pieces of advice, tear the tractor down to the bones, remove all the sheet metal, get all the grease, rust and dirt off before you start and paint both sides of all the sheet metal. I like the looks of removing the bolt-on engine components (distributor, coil, alternator, carb, etc) before painting, I think it makes the result look closer to 'new' than just shooting color over everything. Detail your hoses, belts and tires with Scrubbing Bubbles bathtub cleaner BEFORE you paint (its hard on fresh paint). Also, replace any old wiring, gauges, lights or switches. And fix that oil pan leak you've been meaning to get to, before you start painting. Go for it, you'll have fun and be proud of what you accomplished.
